Need Help With 2002 Toyota Camry JBL Wiring Harness!! [SOLVED]
Tylerrr01
Hey everyone, I have 2002 Toyota Camry and I’m replacing the factory radio with an aftermarket one. I pull out of the old radio and the picture attached is the plug that was in the back of my radio. I bought a wiring harness with matching year of the car and everything but it came in 2 parts and neither of them fit on the original plug. Every video I watch of people replacing the factory radio have 2 plugs that plug into the old radio and mine only has one. Basically I’m just trying to figure out which wiring harness I need that will fit into the plug in the picture attached. Any help will be greatly appreciated!!!
That looks like an aftermarket radio plug. You may be able to plug that into your new radio. Is the replaced radio an aftermarket unit?
It was in the car when I got it. Although the plug doesn't fit into my new radio. I attached a picture of the old radio.
Cut the factory connector and splice your aftermarket wiring directly to the harness. It's a 20 year old Camry.. nobody will miss the factory radio.
503
611
880
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Tylerrr01
Tylerrr01
Pennsylvania
Tylerrr01
SlugButter
    May 4, 2024
slater
    May 2, 2024
