Need Help With 2002 Toyota Camry JBL Wiring Harness!! [SOLVED]
Long story short. Kept looking around for videos and finally came across one that showed the same plug and apparently that wire coming out was the JBL wiring plug and I would have needed a JBL wiring harness and the RCA connectors to connect everything. Although I was able to take off 2 of the other radio system wires and connect the factory wiring to the 2 part wiring harness I had. Therefore causing everything to start and play properly. I will most likely order the JBL wiring harness and connector that was I can still use the JBL amp but for now this will do. Thanks for the help everyone!!!
Tylerrr01
CarAudio.com Recruit
Tylerrr01
Pennsylvania
Tylerrr01
