6 channel amp or 4 channel for 6 speakers?
  • 5
Mwheatley63
I'm looking at getting the (x4)Pioneer Ts-M650pro 110 watt rms 4 ohm and (x2)Ds18 pro Tw220 bullet super tweeters 225 watt rms 4ohm. Looking for a good Amp without breaking the bank. Was looking at SKAR RP 150.4 RMS 150 watts X4 @4ohm and 250 RMS watts @2ohm. Would a 6 channel be better? If so what AMP?
Pretty sure specs on that skar amp are bs.
Buy this:
As much as I hate Skarbage and wouldn't buy them at all. Shockingly their amplifiers make rated power, they use the same chinese cookie cutter factories that others do. Having said that I would buy anyone else over them for the reasons that are known around here.
So what amp would you suggest?
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
550
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
878
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Mwheatley63
Mwheatley63
Forney Tx
Mwheatley63
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
