Subwoofer works just on few song
augismas
Hello all car audio lovers. Curently I have bmw e39 with shitiest saund system( no original amp) For extra bass i added Subwoofer in the trunk and connected amp through hi-low addapter connected from back deck speaker. And the problem is that subwoofer kicks just on few songs from 100+song playlist. On others songs looks like where is no event subwoofer installed. I have alredy tried to install different amp and sub but same results sub works just on few songs. Any ideas?
Any ideas
Your back deck speakers are probably filtered. That means they are protected by a cross over so they only get a bass signal. Since you connected from them, you are only amplifying a very low(hertz) signal not used by most artists. I would connect the hi-low adapter to the front door speakers. Since they get the full spectrum, your amp will amplify the widest signal it can play.
Try replacing the cables as it sounds like something is off with them. And you say "radios" does that mean you have tried multiple ones? If so then that would lead me to the cables.
Yes tried with 2 with aftermarket radios alrefy istalled in the car. Could i some how connect wrong hi low converter?
This is what I suspect now. Try switching polarity on the wires that connect to the rear deck speakers. Choose left or right, not both. If it works, awesome, if not, we are here to help.
Yep, what worked, changed polarity and sub started to work better, but not perfect. Now sub not only kicks the bass but also i can hear some song going from subwoofer. How can i fix this problem?
202
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
883
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
augismas
augismas
LOTHUANIA
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
