Kenwood dmx8520dabs installed in Navara STX won't power on on accessories
  • 2
GeeData
Hey guys,
just installed a Kenwood Car Play (dmx8520dabs) unit in the STX using the Aerpro FP9109XK kit. WIth an Aerpro ISO harness. I have 2 red wire options on the harness:
1. CANBUS ACC
2. Wired ACC
Using option 1 which was connected by default I got no power up of the unit on Accessories, ignition or when running the vehicle
Using option 2 it works on ignition and running but will not run on accessories.
I called Aerpro and they said thats normal due to the way factory units work with modern cars and how their system can;t replicate this.
Thinking more about this - isn't the wire labelled "Wired Acc" simply looking for a 12v+ feed ? Could I not tap into the 12V+ leg of say the Cig adaptor wire and feed it to this wire? Assuming (not ever tested) that the cig adaptor works on Accessories ?
Slightly annoyed that I discovered this little gem after dropping $1200 on the unit and facia kit. I do often listen to radio/make calls whilst parked sometimes like eating lunch or waiting for someone in the car at an appointment etc.dmx8520dabs
Had to do this in a Dodge Ram once. Should be easy to know with a test light or a dmm.
Thanks Marc2112,
Sorry I've probably confused some with my terminology. I assume this is a US based forum and I'm in Australia. Aerpro make aftermarket facia kits and wiring looms for various model cars using ISO looms. Navara is similar to the Nissan Frontier...a 2018 NP300 Navara sold in UK, Asia, Africa and Australia.
We're short on forums in Australia.
Thanks Marc2112,
Yes I got that.
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
188
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
559
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
534
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
GeeData
GeeData
Australia
marc2112
    Apr 28, 2024
    Apr 28, 2024
