Xs power XP3000 battery
  • 2
Okay thank you lol and another quick question.. does it matter if yu ground 2nd battery with amp's ground or should dey be separate grounds?
When I run dual batteries I beef up all grounds in front of vehicle and you'd need a 1/0 power and ground coming from main battery to rear battery...then a ground from rear battery to body and frame if vehicle has one ..then your amp can use the rear battery for ground ...
Front engine bay grounds I do is battery to body ...battery to frame structure ..then body to motor ...
Yea i got 0g power from front to back with 100amp fuse den 0g power wire from battery to amp with 300 amp fuse(since i got 3k Amp) and 0g ground wire from seat belt bolt to amp and my XP3000 battery is grounded in same spot.. n on other side of my car i could use the other seat belt bolt to ground dem separately so im wondering if it would make a difference
With them grounded together it would pretty much be same as if i grounded the amp to batterys negative
436
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
342
705
Doe6oi
Doe6oi
Oklahoma
Louisiana_CRX
SlugButter
    May 4, 2024
slater
    May 2, 2024
