Hey all. After months of research and asking questions, gathering parts, I'm pretty much ready to start my build. Just need a few fuses and misc parts. This will be in a 2021 Jeep Wrangler Ultimate with the alpine premium sound system. Primary goal is SQ, at least what can be had out of a wrangler. Spl is also a factor however, since the top and doors do come off on nice summer days.
Alright so this will be an active 3 way front stage. Grabbing audio signal before it goes into the factory amp via the DSR1. EQ with the DSP, and sent to two amps. One Kicker CXA360.4 will drive the mids and tweets, and the second CXA360.4 will be bridged to run the 6.5 woofers. This gives me ~65w RMS to play with mids and tweets, and ~180 RMS to the woofers.
The front stage will be the Morel Maximo ultra 603 MK2 3 way system. 6.5 woofer, 2.5 wide band mid, and pod mounted tweeters in the dash corners. Woofers will be going into the factory location around the knee area, mounted into sealed pods.. I have not heard them in person yet as it isn't possible near me, but from what I've researched and seen videos of, these seem to be a solid choice.
The woofers will be 6.5s mounted forward firing under the rear seats. The two boxes were designed by Buck here on the forum and built by me. They are 3/4 birch ply boxes ported to 35HZ. I will be running a single FU audio 6.5 sub in each box. Amp rack will be built in between the two woofer boxes and will house the Pioneer amp and the Wavetech LinkQ. Originally I purchased the LinkQ to tune the subs as the full build was supposed to happen at a later time, but now the subs will be tuned from the DSP, and the linkQ will play the role of a bass knob. This amp is cheap and underpowered for these subs at 240W rms x2, in the future I'll upgrade to a better amp that has bass knob abilities built in. Each sub box and the amp rack are designed to be removed easily, as they have to come out in order to fold the rear seats down for cargo hauling.
Power and ground wires are all Stinger pro tinned OFC, distro blocks, fuses, sound deadening and additional hardware are also Stinger. I'm not sponsored by Stinger lol, but their stuff seems quality and I can source it locally.
Future plans are to continue sound dealing the vehicle, roof and floors first to help keep out road noise. I will ***** the system loudness with the top and doors off, and determine if I need speakers in the sound bar. If I do, I'll likely pick up some super efficient comps, possibly the Morel Maximus 602s, and maybe run a set of taramps micro amps on them. They would be on an on off switch, that way they can be off in normal conditions as to not screw up the Soundstage, and turned on when the top comes off for extra volume when imaging doesn't matter anyway.
Its winter and I'm working a lot, so this may be a longer build, but I thought I would go ahead and get the thread started. If you have any suggestions or things you would do different, feel free to post it since I'm always open to new ideas.
