Adding shallow mounts to Jeep?
jeeper2269
I’ve never been impressed with shallow mount subs, however it has been a long time since I’ve heard any. As I mentioned in other threads, I have a 12” FI Q (older version) powered by a teramps 3000.1.
The current enclosure is just a bit too big, as it was built for another vehicle.
I am trying to save up to get a smaller enclosure built for it now. I am thinking it will reduce the performance, so I am wondering if I could add some shallow mounted tens under the rear seats and make up for the loss. (Down the road, when funds permit). Or,,, would it even be worth it??
The enclosures I found seem pretty small, as far as volume.
Maybe this??
Again, I really don’t know much about them. Maybe running one, instead of two, would be better.
do you own a saw? if so build your own box.look up specs. on size of box you will be surprized w/ the results . its pretty easy...check out mine.
Attach files a cardboard tube some foam rubber and some birch skins.BOOM!
that was my sub enclosure,this is my current box.totally enclosed.
It's best to show the finished product rather than the work in-between to show off a standard a person could reach.
With that said, if they ask for a how to and want something like yours, that photo you did show would be fine to show a process up until the refined version.
jeeper2269
jeeper2269
Somewhere, OR
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
