Title says it all. I broke a tinsel lead on the neo Beehive sub I'm running. It broke about 1/4 inch away from the solder joint at the terminal. I went ahead and re-soldered it and it's playing again for now.
What are my options for a permanent fix without a recone? I've seen some subs use direct 12ga wire from the coil, could I just cut a length of 12ga and solder one end to the tinsel by the coil and the other to the terminal?
