Alpine PDX amps
Sounds good. I’m not familiar with pioneer sets so I’m not sure if they’ll have much mid bass but won’t know until you install. Make sure to deaden what you can on the door and seal what you can. That’ll help tremendously
I go active these days so I’m not too familiar with component sets. I was using an Infinity 90CSX that I got for $180 and I thought for the price they were pretty nice. It really needs the midrange though to finish it off.
Here it is
That paint doesn’t look rough. Goodness what did he do to that thing.
It has paint chips around the edges and the cover that covers the amp settings.
How is the Rockford Fosgate T2's. Im trying to compare which is better and would work best with my amp and get good mid bass.
Heres the fronts and rears.
I don’t have experience with Fosgate speakers either. Spending time and money deadening and sealing the doors will make $10 speakers sound better than $300 speakers. Just like how a proper box will make a subpar sub perform better than an audiophile sub in a bad box. Do you plan on deadening and sealing? I’d still ditch the rear speakers and spend that money on a dsp
What DSP you recommend? And will I only need a DSP of I go fully active in the front? What if I use the crossover it comes with and coaxial in the rear. Will I still need it
You’ll need a dsp to go active since your amp isn’t able to cross the tweeters over properly (I don’t think so at least). Dayton DSP is a great budget option but I haven’t used it. I have used the JL TwK and thought it was easy to use and worked great.
Just came across another good deal but it's a 5 channel amp. There both going for 250 which one is better and should I grab?
Alpine PDX V9
Rockford Fosgate t1000x5ad
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
181
434
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
Icecube91
Icecube91
Vancouver, BC
Clifff150
    May 16, 2024
    May 16, 2024
