Help upgrade sound 2020 Porsche Macan S
FernandoGRA
porsche does not give any reference or diagrams of its audio systems, my Macan S came with a bose 14 speaker Surround System, blah blah blah. It is very difficult to find specific switch options using the same spaces of the speakers and amplifier, the car is wonderful, but the audio from Bose is unpresentable.The only thing similar in dimensions that I have found is the System Gladen One 201 for BMW because the measurements match 1 "for the tweeters 4" for the midrange and 8 "for the woofers, that is all I have found that allows me to keep the connections standard and thus everything remains inside the car and not in sight damaging the installation invisible original I really appreciated some advice, best regards
What's wrong with the Bose system?
Bose uses standard speaker sizes just like everyone else. What frequency range are you unhappy with? I doubt you'll want to go as far as replacing every single speaker in the car without at least getting a larger subwoofer. If you're unhappy with the bottom range then you'd be better off just keeping everything the same and adding a larger sub and enclosure with an amp and LOC. Also get a damn adapter, don't ever snip a wire and ruin that car's resale lol.
Example for replacing bose speakers.
These will sound better than (almost*) anything bose makes most likely. The measurement to tell if it'll fit is the outer baffle, these are 6.5" which is extremely common for midrange. Nothing Bose put in that car will be of a non-standard size that Hertz or Focal don't make.
FernandoGRA
FernandoGRA
Lima, PERU
Lasherž
