Replacement for Alpine PXA-H800
andeee
Junior Member
Hi all,
Seems like my H800 may be dying or at least it's not working properly anymore. I think the RCA ports for the tweeters is killing rca cables or something as one of them works and the other doesn't sometimes. Don't think it's the amplifier because I just replaced it. What would be suitable replacement for it? How are the Helix processors? The DSP .3 looks like a close match price wise, maybe worth stretching the budget to the Pro?
I had issues with my H800 as well....RCA issues and it seems the processing fails sometimes...can't really put my finger on exactly what's going on with it.
I'm replacing it with a Dayton DSP-408....it's a basic DSP but covers all of the bases except a center channel, which I won't be using anyway.
The h800’s have had some internal grounding issues if your handy with a soldering iron you can pop the case and go on the inside and touch up the grounds and it usually fixes the intermittent output issues .
Hmm, I'll give it a look. I bought it about 8yrs ago now, I guess when they were first around? Have They always had this problem? This only recently started happening.
Do you have any specific info on this? I wouldn't mind trying to fix mine. Thanks!
Anyone with soldering experience should be able someone that does basic electronics repairs could handle this . Mainly your just touching up a few cold solder joints around the rca outputs on the brain case . If there is a CB shop at a truck stop in the area they can do this type of work for cheap . It’s not really a bad part repair it’s just helping the connections get better contact .. it’s definitely worth trying before spending a lot of money.
Thanks...I'll give it a shot this weekend. The RCA connections themselves on the H800 didn't impress me too much...half of them pulled right out of the unit when I removed RCAs.
I’ve had amps do that .. if able upgrade the RCA’s to chassis mount style a far better connection . I don’t know how to add a link by phone but I photo shot what I’m talking about you can find these on search on eBay ..these are fairly cheap good reviews and would make a nice upgrade over the cheap Alpine factory RCA sockets
Polk Audio are some great speakers for the money https://www.amazon.com/dp/B072Q9BCGH/?tag=caraudiocom-20
93
i wasnt aware of that, thanks for the link! ill be ordering a pair of these
626
Polk Audio DB Series with or without an amplifier. MM Series on an amplifier
470
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
I like your idea. My rear speakers are also almost invisible. I didn't remove them, but I cut some baffles to let the subwoofers sound escape the...
andeee
Junior Member
andeee
Australia
Louisiana_CRX
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
