taramps md8000.1
ekah
bought it
seems i turned the gain up almost more than half way and its nowhere near my cab1600
but then again i havent turned the volume up to hit that cliping light
but the volume i usually rest on is 20 out of 42 and its no where near the cab
is it because of electrical
You can’t really compare the knob position between two different companies. Turn it up. The Taramps will make 4x the power as the cab if you have the electrical.
Also, check your crossover settings. The Taramps is a full range amp, and it is easy to set it so their is no bass.
I guess I'll just turn up the sounds until clip wherever the gain is on and then lower when needed.
I would assume I would get more power even with stock electrical.
I'll send pictures where filter and gains are when I get home
bought it
your head unit should be 90% of your max volume. Sub level should be up. now reset your gains again. Make sure your high pass filter is as low as it can go and low pass around 100hz.
ekah
ekah
hawaii
Jeffdachef
