Waterproof speaker grills?
Tell me more about your cold air intake. Does your intake/wrap let water through? Does your wrap let air through, but not water? Is sound moving air, but not necessarily water? You are proving my point without realizing it. AIR IS A FLUID. WATER IS A LIQUID. ALL LIQUIDS ARE FLUID, BUT NOT ALL FLUIDS ARE LIQUID. Gases have smaller molecules than liguids, generally speaking...
I'll repeat; please stop replying to my thread if you don't have an answer to my question. I emphasize PLEASE. I'm here for advice, not to argue. I don't want to hear that it can't be done; I'm here to learn how it CAN be done.
I do have an answer. Just like everybody else on here. What you are trying to accomplish is physically impossible. Sound waves would get interrupted. Mount detachable speakers up high and protect your amp. Treat your **** like a boat. There is a reason why submarines don't have exterior speakers. Do your best and good luck. Try wrapping them in a K&N foam filter. Quit dragging up this shitty post, please.
Not to thread Jack, but I would like to run 4-15's in my Prius on stock electrical and a one cubic foot ported box (tuned to 28hz) with an 8,000 watt amp in my ashtray. I don't smoke, so, I don't use my ashtray. I'm looking for SQ and SPL. I listen to music from Gospel to Gangsta rap. Any help would be appreciated! It must have extreme lows and still hit the high notes.
You would probably provide a more factual answer to this post than you provided me.
Angle the speakers down and make a grill that have louvres that are level. Similar to how a mini blind can be seen out of but doesn’t let light enter the room. Not water proof, but it would limit how much water hits the speaker. Any water that happens to get in would at least not stay On it long.
My cold air intake. Note, it doesn't throw out high quality sound.
Detachable marine grade speakers mounted overhead. Mount amp in an aluminum box with a louvered top. Run all wiring inside the tubing of the chassis. If it's raining or you are washing your ride, then, detach the speakers. Done. Drop the mic!
103
145
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
762
jt4x4
CarAudio.com Exclusive
jt4x4
ND
Bobbytwonames
slater
    May 2, 2024
slater
    May 2, 2024
