New Guy, New to Car Audio
dsm600rr
USA
Hello all. I am looking to add a Sub to my 2020 Chevy Equinox and looking for suggestions. I do not want anything crazy, just nice clean bass.
I am currently considering:
SUB:
AMP:
Thoughts / Suggestions?
It all depends on what you listen to, if you’re gonna keep your factory speakers I would t get anything bigger than a 8” sub. And maybe look into a under seat subwoofer with a built in amp.
Perhaps this setup?
Perhaps this setup?
This would be a great start. Note: enclosure will make all the difference. If you want maximum output from this woofer then I would go with a enclosure built to spec. No matter what sub I buy I’ll always build a box to the manufacturer specs for the sub.
I hope this helps
That demon and crescendo pairing recommendation is solid....those jl options you inquired on are overpriced for what you’re going to get.
Since it’s a 2020 vehicle I would initially prioritize more of your budget on Ensuring a quality de-equalized signal, maximum amp efficiency (low current draw for delivered output, a sub that won’t consume your whole trunk, and An enclosure built to the sub specs. He a couple products to consider
Oem integration:
amp
sub
budget?
how much room do you want to give up for a box??? WxHxD?
and not just for this car, what about next car?
On second thoughts get a d4 sub and run it at two ohms
this amp would be great for that sub. Then If you ever swap vehicles(after your lease) you could throw in another d4, have a one ohm load, and A good amount of power for two subs...if your next car meant more bass which happens a lot
dsm600rr
dsm600rr
USA
Jeffdachef
    May 31, 2024
    May 24, 2024
