Bass problems
rlwjr1
Junior Member
I have a 4guage hot wire going to a distribution block, with two 8 gauge hot wires going to two amps. one 8 gauge is going to a 380 watt RMS class AB Amp going to door speakers and 6 x 9s in the back. The other 8 gauge hot wire is going to a Mono block class D Alpine Amp pushing 500 watts rms to a single 750 watt subwoofer. I can turn the subwoofer off and turn it up as loud as I want, no problems. But, with the subwoofer turned back up, when I turn the volume up to the sound I want, the system, sometimes ti turns the breaker completely off as,, I have a breaker instead of a fuse, It is a 100 watt breaker. Other times the sound goes off , then comes back on about 3 seconds later. I also have an 8 gauge ground wire going to each amp. I switched the ground wire around. It did not help. I switched the hot wires around , and it did not help. Any ideals please. The system sounds great, with my JVC 13 band equalizer head unit and the alpine amp hits the single subwoofer just right. But , it irritates the hell out of me either shutting off or especially / kicking the breaker off . My alternator is also 110 amp alternator, and battery is less then 6 mons ol d
You never mentioned if the big 3 has been done yet, that will certainly help your voltage a bit, not a lot but a wee bit. A HO alt is key to upgrading any electrical running multiple amps. And running 1/0 good quality wiring too.
What popwarhomie said and could be because your circuit breaker might need a higher amperage one. How are your gains set on the amps? What's the audio consist of? And wiring brand name, and yes it matters.
And why do you keep calling the wiring "hot wires"? Are they hot?
Bad wording, I called them hot, but I have a 4 gauge positive wire comign from batter, to distribution block , and then 8 gauge positive wire going to each amp, And 8 gauge ground wires coming from each amp . as far as brand. not sure. I had them for a while , cannot remember .
no just bad term from me. not hot , I should have said positive wires not hot
If you are popping a breaker you either have a short, pulling too much amperage, or your breaker is bad.
It does not pop the breaker most the time. The music just fades off for about 3 seconds then comes back on. But if I turn down the subwoofer on my car audio head unit. Then it never gives a problem. I even changed the ground and positive wires around to see if it would help. It did not
what do you mean when you say "you changed the positive and ground wires around"? They are both 8 gauge correct?
yeah ive got the 4 gauge positive into the distribution block from battery. then 2 8 gauge going to each amp. SO I changed them around, to see if that changed the results any. I did the same with the ground wires. I did it just to see if one of the positive or ground wires were bad. I may buy a new 4 gauge or change the distribution block or I may take it to the local audio installation place . Let them check all the wiring to see if it reads what its suppose too. That wiring is to expensive to go changing it if you not sure that is the problem
To me, it seems that the breaker is the issue. Its drawing too much amperage and flips. You said you have a 100w breaker? I could be wrong here but how is a 100w breaker gonna work with a total of 880w (380w door speakers and 500 watts to sub)?
Are you you sure you mean watts and not amperage for the breaker?
Now, the breaker could be bad. I will probably just take it to the local installer. Have them do a check on the wiring . I do not have the tools to check it myself. That way I can either find out if wiring is the problem, or eliminate it if it is not the problem
yeah I did use watts instead of amps I meant 100 amp breaker
^^^^This. I would try a 150 amperage circuit breaker. And Crutchfield only suggests that for one of 2 reasons 1 safety on their part and customers and 2 a marketing thing to get you to spend more $$. Most of us here don't run circuit breakers.
Also I might add how are your gains set? Should match your hu pre output voltage.
rlwjr1
Junior Member
rlwjr1
Rogersville, TN
Gunk
