Look at the md3kThis one? I checked out the SFB also and I noticed in the picture on D4s That there were dual power and grounds connected to it. Is this how I would make sure that it receives sufficient power. By dually connecting the power ground from up front along with the power and ground from the extra battery?
Yeah but common comparison is that it’s less friendly for voltage fluctuations and it’s slightlyReally? I thought the Bass 3k was built a little beefier than the MD.
More expensive. I think that was the skinny on the bass and the hd compared to the md. I could be wrong tho
I was looking at this video if you're curious.
Taramps Bass 3K Amp Dyno and Review
Time to test another Taramps! This time the dealer exclusive Bass 3K, unlike most Brazilian amps is designed exclusively for subwoofers. We will take a closer look at this amp, test it on the Amplifier Dyno and also compare it to the HD3000 to understand the differences. See other Brazilian amps ...www.stevemeadedesigns.com
skip to 9:50 for comparison
