Recommend 5 channel. Kenwood HU with Active Focal
MysticMathias
My first build in 6 years. Thanks to a few of you for helping with my HU selection and questions about going 2 way active. I need help with selecting a 5 channel to help tie in my Kenwood Excelon DMX760S with my Focal ISU 570’s. Doors are very well treated. Open to any and all recommendations. Trying to stay under $700 on the amp.
Not sure what sub you're going to use and what ohm load but sundown has a nice 5 channel within your budget. Being from sundown I'm sure it does rated plus designed and built well.
700$ is a big budget for a five channel. Most 5
Channels are capped on the substage wattage they can deliver and the impedance wiring they can Achieve (most are two ohm). For the 60-80$ cost of an additional 1/0 sub amp kit you can do two separate amps for likely less than $700.
-what is your ideal substage plan (#subs,size,watts)
Care more about mids and highs. So I always plan a build around that. The sub I want is one that fills the frequency void left the components won’t produce. I’m in a single cab truck and want as little components as necessary. 600 watts for sub stage for me is plenty and 75rms for the tweeter and mid should be perfect for efficient components.
Care more about mids and highs. So I always plan a build around that. The sub I want is one that fills the frequency void left the components won’t produce. I’m in a single cab truck and want as little components as necessary. 600 watts for sub stage for me is plenty and 75rms for the tweeter and mid should be perfect for efficient components. I’ve thought about the Dayton 10, but I’d like to do a Focal 12.
One thing I’ve noticed about reading reviews is those who cannot spell offer very colorful and misspelled adjectives to describe products. Take...
I’ve never owned them but have heard a lot of crossfire products and like them a lot.
22
At the moment I'm trying to do a SQ system on a budget (oxymoron I know) but will upgrade gear as I can. I will also be running 1 or 2 subs, so it...
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
822
MysticMathias
MysticMathias
Austin TX
MysticMathias
    Apr 28, 2024
    Apr 28, 2024
