Time for new HU, please help me with a few questions
Hi Gurus,
Please bear with me: I have a factory stock Bose nav unit in a 2007 Vette. Last straw was losing the clock on the screen (aside from zero connectivity).
For now, I just want to replace the HU and I'm looking at the Kenwood Excelon DNX995S or perhaps the Pioneer AVH-W4500NEX. I'll prolly keep the car another 2-3 years, so I don't want to go overboard with new speakers, amp, etc. I know this limits SQ improvement. I would like 2 camera inputs, HD radio, and use Android Auto for nav, and have premium Spotify.
1. I've heard that Bose speakers offer low impedance. Will that damage a new HU without other modifications?
2. I have a Galaxy S7 which I'll likely replace in the next couple of years. Is a USB extension still a problem? I couldn't get one to work with AA in my truck with an AVIC NEX 8100 a few years ago. But it would be way more convenient as opposed to pulling the dash to install a type C USB when the time comes. Or can I install a micro usb in one port and a type C in the other? I know that sometimes (always?) one port is only for charging.
3. Thoughts between the two units? Some folks here said Kenwood double dins are buggy.
I'm sure I'm forgetting something, but I'll stop here for now. Thanks for your help!
Hi Gurus,
If I were buying a well priced 2din it would be the pioneer unit you mentioned. Pioneer headunits check off all the boxes for me including user usability. If I didn’t get a pioneer i would probably get a pricier alpine.
Those replacement head units are meant to run 4 ohm speaker impedance. It could power 8 ohm but with likely decreased power output. I wouldn’t chance 2 ohm. Best bet is dig around on vette forums and find out exactly what the speaker impedance is. Is there a separate factory amp on that vehicle
Thanks for the recommendation! I'm embarrassingly ignorant about both the speaker impedance of the stock system or if there's a factory amp, but I will try to find out on the Vette forums.
851
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
855
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Chicken Vindaloo
Chicken Vindaloo
Merritt Island, FL
Chicken Vindaloo
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
