amplifier help
Thomas Brady
So not long ago i had a single DD612 with a DD am-1 amplifier (500 watt system which caused headlight dimming and had a Max Current Draw of 50 amperage) which i just recently got rid of because I bought the new DD712(D2) with a dm1500a amplifier. Keep in mind I drive a 13' Honda accord.
I was going to get the dm1500a installed with a second battery but this amplifier has a max current draw of 230 amps. 230 amperage amplifier for a 1200 watt sub  would take a toll on my stock alternator from what i've been told. I was thinking I should go down an amplifier and get the dm1000a that has a current draw of 90 amps. My thought process here is although the DM1500a is 1500 watts at 1 ohm, the DM1000a is 1000 watts at 1 ohm but with far less current draw. The sub i have is 1200 watts rms.
Would my alternator be fine with the dm1500a or should i go back and get the dm1000a?
keep the bigger amp, get a volt meter, set gains via voltage drop done..
Thomas Brady
Thomas Brady
Jeffdachef
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
