Waylon Daniel Eric Hagin
i have an alpine mrv-m1200 and a rockford fosgate p3d4-12 Just want to know the best way to wire the amp to the sub to get the most out of what i have without risking damage to amp or sub
Amp specs--
[*]Total power output: 2400 watts
[*]CEA-2006 Compliant Amplifier
[*]40% smaller footprint than its predecessors
[*]Pulse Width Modulated MOSFET power supply
[*]Wired remote bass level control sold separately - Rux-Knob
[*]Alpine RUX-KNOB.2 is also compatible with this amp
[*]LED power (green) and protect (red) indicators
[*]Soft start turn-on
[*]Mono channel operation
[*]3-way protection circuitry (thermal, overload, and speaker short protection)
[*]Dual speaker terminals simplify the hookup of multiple speakers
[*]Heavy duty aluminum alloy heat-sink for extreme heat dissipation
[*]Input sensitivity:
[*]Frequency Response: 7 - 400 Hz
[*]Total Harmonic Distortion @ 2 Ohms (THD): <0.2%
[*]Signal to Noise Ration (1W into 4 ohms): >85 dB
[*]Variable low-pass filter: 50 - 400 Hz, -24 dB/octave
Subwoofer specs--
Amp specs--
- Alpine MRV-M1200 V-Power Digital Amplifier
- Class-D Full Range Monoblock Amplifier
- RMS Power Rating:
4 ohms: 600 watts x 1 chan.
- 2 ohms: 1200 watts x 1 chan.
- 1 ohm: ------------N/A------------
Low level: 0.4V-10V
Subwoofer specs--
- 12" subwoofer with dual 4-ohm voice coils
- anodized aluminum cone with Santoprene surround
- hybrid StampCast basket provides strength while minimizing weight and resonance
- Vertical Attach Surround Technique (VAST™) increases cone area
- power range: 300-600 watts RMS (1200 watts peak power)
- frequency response: 28-250 Hz
- sensitivity: 85 dB
- top-mount depth: 6-11/16"
- sealed box volume: .75-1.25 cubic feet
- ported box volume: 1.79 cubic feet
