New 12" Brahma
  • 6
i received mine last week....
Looks nice... how does that Brahma sound in there?
beautiful....box is your design(Fi SSD), but the guy i had build it for me f*cked up on port length, ended up being 26hz tune instead of 30hz, but i think it worked out better at 26hz, i might throw some 2x4's in to bring it up a bit...but overall more than satisfied....almost too loud for me at times
i dunno its kinda hard for me to get in there and actually measure it, but using a tone generator there is pretty much no cone movement at around 26hz.... he used different bracing pieces,but i wouldnt think those would not displace enough volume to effect it that much....something aint according to plans...but i like it so far so thats all that matters
Did you test the tune with the SSD?
Was it already broken-in?
I'm thinking that if any volume was gained with different bracing and a loosened-up sub was used... it would lower the tune noticeably.
Ah crap... I'll quit cutting-up the corpse so to speak... as long as you're pleased
tested with SSD and Brahma both same result.... 26ish
extremely different suspension between the two subs...Fi after a year is still extremely tight, Brahma brand new was as loose as my wifes *******
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
YourNameHere
CarAudio.com VIP
YourNameHere
Jeffdachef
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
