RainbowCamaro
Okay so I ordered 2 12'' Subwoofers from amazon, they arrive tomorrow, it's the "MTX Audio Terminator Series TNE212D 1,200-Watt Dual 12-Inch Sub Enclosure" ones.
I want to run them both with my amp, how would I do that. I've only had 1 12 before. I was wondering if I could run them (obviously not at peak power or anything) with my amp. I am going to get a new amp if needed to run these things. Yes I know they might not bump to their max potential with my amp because it says 1,200 Watt. I also need help wiring these. How would I wire these? What I'm thinking about doing is just doing 2 pos wires and 2 neg, 1 in each sub and put them in the pos and neg terminals of the amp. It would be sending both of them 600 watts right? (Again, I know not to turn it up all the way because it will blow my amp from overheating it, or it will blow the subs from the distorted signal of the amp) I just need to get them working and I've not wired subs before like I said other than the one 12, its pos and negative thats it.
This is in the "Highlights" section -
AMP: Alpine MRP-M650
- Power Handling: ( Max: 1200 watts total, Peak: 800 watts total, RMS: 400 watts total )
- Internally wired to a 2-ohm final load
