Sub box cut sheet
  • 2
Plenty of room . skar audio rp2000.1
That's fine... what vehicle... the orientation matters
A 31hz tune huh? lookin' to get low I see... I had 4Kish on mine and they did well... but unless you know your equipment's limits I wouldn't advise a new guy to do the same.
Just what to cut each piece. Yea I think that's gonna make it bubble lol
Tell you what... provide useable dimensions and ill do up a nice 31hz design for your power but leave room to strap those RP's at 2ohm if you want to really flex them someday.
I MIGHT be able to come-up with something...
You.got tools and a router?.. id like to do something decent.
What about 37w 16h 18 d
Well it MIGHT be doable in that space with an aero and smallish volume but I wouldn't design something like that... "ugh!"... I'm sorry man... a slot with your power and tune just ain't gonna work in that space (Sub displacement, double baffle, port volume and bracing adds-up) those subs need some volume and some port area.. oh I can do something if you find more space... what's the deal?.. I thought you had a good sized trunk?.. take the bodies out and make room. Those subs LOVE a decent sized box with a lotta port.
I do have experience with those exact subs btw...
I'm saying width, depth or height... something's gotta give
Even if I single-ply the thing, leave out bracing and port it for 2K only you gotta find some space.
Think you can work off this?
I thought you'd find that more useful than a "cut sheet"
I left the height & width but had to change the depth a bit... but that ^^^^ should get low and do well.
Good luck with your build.
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
A little DAP will do ya, drill, feed & seal, done.
579
Brick20
Junior Member
Brick20
Chattanooga
shredder2
    Apr 28, 2024
    Apr 28, 2024
