PPi 356cs first impression
WOW, didn't expect anything to be better than your RSDs honestly. You should buy every set of the ppis then. Don't forget to not properly set the EQ, and stage them at all because it doesn't really matter to you... dumb ass.
I never said that staging and equalizing was a waste of time. I just don't have the resources or knowledge to properly do it. Get off your high horse, not everybody on this site is as smart as you.
Tuskilla: Mount them in the trunk. They are almost too big to mount inside the doors. You will have to run two sets of speaker wire on each side, but then you will have the option to go active if you so choose. Underneath the front seats would work too if you wanted.
I run the ADS earlier version,but I did install a set of PPIs
in a buddys car along with an older PG amp xenon which was 200Wx2
a raw door with no deadening or anything they kick ass
visually the speakers are almost identical to mine
sound wise they are equal to my ADS's which I paid quite a bit much more for
2 years ago...IMO there is nothing better at triple the price -I dont like to compare
speakers because they all sound different,even the vehicle can change the sq a ton
I have to get another set to keep on hand now this deal will run out as PPI I am pretty sure will
not make them much longer
I run the ADS earlier version,but I did install a set of PPIsin a buddys car along with an older PG amp xenon which was 200Wx2-
seems like a pretty accurate comment here. People just can't get over the fact they paid more for something that just ain't as good as these
Everyone who's getting in my car ask how much the comp set cost me and they're all astonished by the price i paid.
hows your response in the 80-150hz range?
i have a real problem here and my doors are fully deadened and sealed
it doesn't seems to dropout till under 80hz in my setup. But i, and pretty much everyone, love overexagerated midbass... those aren't midbass heavy...
If you got some headroom from your amp, just try to eq that part a little, just a small boost in the 100-125hz should already be noticeable.
are they bottoming at full tilt?
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
I am wondering if anyone has heard or have information on the new PPI vertical PC amps. Are they good for a budget sq class D amplifier. Any...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
Xprime4
****in' canadian
Xprime4
Quebec, Canada
stocker08
    May 24, 2024
    May 23, 2024
