How does a SoloX 18 sound?
please, stop the trash talking in this thread... If you want to have a argument, please do it in the lounge or pms or something
Solo X + 18" x 2 @ 6500? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
there is no sound quality at 150 db.
sorry buddy
Word
I'd go with the four 15's.
your good at it.. confused the hell out of me. so whats your vote... Without being facetious
i think you would be happy with a dd 3515 or if you have the power a treo ssx, either way, ported. if you are going with two woofers, definitly two 3515's. throw them like 2500 watts and call it a day. the solo x is too power hungry and too inefficient for my likings. i have dealt with two of them and wasnt overly impressed. i have heard good W7 setups keep up just fine with the solo x 12".
maybe you guys have a different definition of SQ than I "tonally correct, transparent and accurate"....
which L7's and Solo X are none of the above
In the right install the l7s can be;) thus being the reason why they have won sq awards many times.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif They definately arent the best candidate, but are very capable with some work..
I'd rather have 2 midgets making farting noises in a wood box than put L7's or Solo X's in an Sq car
I explained in another post why a solo x/l7 could be in a winning SQ car. To sum it up, the low end of the musical spectrum isn't that important in a SQ car, there's10,000 other things you'd need to worry about first. Just some low end presence is what your looking for, which just about any sub on the market will give you if you tune it right, you dont' need high output levels for SQ comps. Like someone already said, if your not wanting to "compromise SQ", in a DD and you want to use a solo X, your confused.
I could really give two craps what you think....sub bass is very important..you may not be playing a huge bandwidth...but if it doesn't sound right then chances are you'll localize it which draws the stage back...
Wow.. never meant you guys to think I was building a "SQ" car.. If I was doing that it woud probably be something like 3 tens in a real clean install... I want to be REALLY loud, obviously by choice of sub... I just dont want it to sound like arse at the same time. I was really dissaointed by the curve the SoloX ploted and the L7 curve, looked like it would get real loud, but have a good response across the range and have a low cutoff.
38
431
10
996
DarkFox
DarkFox
Old Lyme, CT
Polecat
    May 24, 2024
    May 23, 2024
