Ruffy 10+ year member
Death to the salad eaters
I'm thinking about two Diamond D6's. Unsure about 4ohm dvc or 2ohm dvc. I'd probably go with the 2ohms that way I can run the amp at 1ohm and not have to pay as much for a 1000w @ 2ohm+ amp. I am worried about heat though so I'm still undecided on the amp. I was looking into a ED nine.1 but have reconsidered. Looking to spend under $300 for the amp.
Do the D6's handle that kindof power safely?
What other subs are out there for the same price-range of $300-400 for two 12" subwoofers?
Also when you pump 1000w into dual 12"s. Do they essentially both get the 1KW RMS or is it split in half between the two?
Finally How would a Alpine Type-X Vs the D6 compare? The Type-X is more around the D9 price range.
