Changed My Mind
this is my bro.... after rise they will not see .5 anybody knows that and yes they ran cooler than one because we clipped when we ran one and not at all with two. never ran it full tilt cept to blow the hdc3's up so i could have them. and at full tilt was right at 12 volts...and the batts are beasts ask murilo (sp?) from sounddigital //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
im running a memphis 16-VBF-1 line driver' date=' running directly from my ipod to the sub amp, and using a ipod tape player thing to run the mids[/quote']
low low dirty signal
as soon as you put good 5v signaal to them from decent h/u you will see a change and yes rise is a factor g/l/w/b
how is it a low dirty signal. its getting all most 5v from the line driver. id really like u guys to come to a comp and hear our setups lol
I think what hes trying to say is that a line driver only amplifies the signal given to it. Meaning if you only have 1v going into the line driver it will beef it up and give you 5v out but it will most certainly be a dirty signal. Make sense?
It can only enhance what it sees.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
There's no reason to assume the stock h/u is producing a clipped waveform. If he maintains a reasonable volume setting on the h/u, its resonable to assume it will output a clean signal. And an amplifier does not require 5volts input to perform well, that's why amplifiers come with adjustable input stages (gain knobs).
I do not use the stock HU to control the gain for the bass, the stock hu is purely for my mids and highs, my ipod is what controls the bass gain and the memphis line driver , plus my gain knob, i can turn my hu all the way up or down, it doesnt effect the bass, only the mids and highs
TrUnK WaNgIn'
Pimp Of The Year
TrUnK WaNgIn'
Knoxville TN
TrUnK WaNgIn'
    May 31, 2024
    May 24, 2024
