Car audio not working
  • 3
Errinar
Hi I've been searching around google for the last couple days and can't find a solution for my audio problem. I have an 04 Sunfire with the stock speakers and a sony head unit that I've had for a few years now. The audio on the left cut out completely a couple months ago and the right side worked just fine until a few days ago. The audio on the right will either come on when the car turn on or it won't. It doesn't cut in and out at all it either works or it doesn't. I checked all of my fuses, I pulled the head unit out and checked the fuse on that along with all the harness wires. I pulled the door panels off and those wires looked good as well.
The sony head unit is powering the speakers? It doesn't sound like a blow speaker, but either a loose wire or bad head unit. Try disconnecting and reconnecting all the wires. What's worth doing is investing in a DMM (digital multi meter), you can use that to diagnose most problems. For example if the speaker is bad, you can measure resistance across its coil. If it's blown, will be close to 0. You can also use the DMM to test the HU,
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
676
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
420
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
950
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
623
Errinar
Errinar
Cleveland, Ohio
Errinar
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
