Audio System for 2001 Chevy Impala (Base 3.4L)
  • 1
dprox54
Hello CarAudio forum, I came to this community to figure out any information that anyone may have regarding the modification of this car.
I would like to put a new and amplified system in this vehicle but there are some limitations I may reach. I have tried to wire this myself once before and it didn't allow the operation of my door chimes and warnings. Is this necessary? I would like to keep this if allowed but I am still stuck a little bit on what I need to do it right!
I have a used 4 channel amp coming, a Kenwood touchscreen stereo deck, and a decent amount left in my budget.
I would like to get the stock system working with the new deck as a first priority!
Any and all helpful responces will be greatly appreciated!
Thanks!
Domenic Parker
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
318
16
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
dprox54
dprox54
Comstock Park, MI
dprox54
