Audio System for 2001 Chevy Impala (Base 3.4L)
  • 1
dprox54
Hello CarAudio forum, I came to this community to figure out any information that anyone may have regarding the modification of this car.
I would like to put a new and amplified system in this vehicle but there are some limitations I may reach. I have tried to wire this myself once before and it didn't allow the operation of my door chimes and warnings. Is this necessary? I would like to keep this if allowed but I am still stuck a little bit on what I need to do it right!
I have a used 4 channel amp coming, a Kenwood touchscreen stereo deck, and a decent amount left in my budget.
I would like to get the stock system working with the new deck as a first priority!
Any and all helpful responces will be greatly appreciated!
Thanks!
Domenic Parker
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
931
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
dprox54
dprox54
Comstock Park, MI
dprox54
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
