what the hell is the sub displacement?
  • 4
It is the ammount of space inside the box that the sup displaces. Let's say you want a 1.0 cu.ft. box.
If you make a 1.0cu.ft. box and have a sub that displaces .1 cu.ft. You'll end up with a .9cu.ft. net....which would mess up the tune.
I think he was asking about the RE12s displacement, not what the term "sub displacment" meant. At least I hope he meant that.
Thanks guys, I appericate it. If I just use .07cu feet will it cause any problems? I dont have to be 'exact' do I?
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
154
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
257
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
7
306
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
346
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
300
SenateS684
SenateS684
SD
AzGrower
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
