cl-641 crossover
  • 2
hpsaheli
Atlanta
I got my cdt 3 way component about 4 months ago and it has been hooked up to a mtx 404 (4x50@4ohm).
Each set of cdt has 2 crossovers, one for input (from amp) which goes to the 6" midbass and also has an output for the other crossover(this one for 4 and 1).
But since I have a 4 channel amp I gave two channels to two 6" crossovers and the other two channels to the two 4 and 1 crossovers.
Also it has been hooked on for 4 months now, and it sounds okay.
But since the each set is suppose to be 4 ohms I was wondering what ohmage they are in now!?
So I think I should cross the mtx to 2 channels and give each set about 150. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks for the help
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
371
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
hpsaheli
hpsaheli
Atlanta
hpsaheli
    May 22, 2024
    May 22, 2024
