Polyfill. Chime in please. (yes I googled it too)
  • 4
ThatChevyGuy
sue me, its a ford.
13,454
26
Georgia
EDIT: INFO FOUND Thanks
Okay, been reading and reading.  Still can't find answer I'm after exactly...
Specs say  5.5 cu ft net enclosure volume sealed.
It's an Infinite Baffle suited subwoofer, and box space is limited, I Like sealed boxes, so going ported is not an option
I don't have a trunk, so I'm building an 8 cu ft net shared chamber enclosure...
Can I Stuff The 8 cube box with enough fill to where the subs would behave as if In the recommended 11 cubes?
How much can I add without big negative effects? is there a chart with fill amounts and expected volume correlation the sub "sees" ?
Sub info: Lanzar dctoa18 (IB suited)
Qts : 0.75
Vas: 14
FS: 30hz
I wouldn't. That poly fil will change how the sub sounds and I think shrink the internal volume if I'm not mistaken. Poly fil is mainly used in home audio, not car audio. If you have a well designed box for a sealed enclosure and built properly, shouldn't need poly fil.
My past experiences with polyfil yielded amazing results.
15" in 2.25 cu ft SEALED with about 2 lb (iIRC) of poly REALLY brought the lows out
It made the sub behave as it was in a bigger enclosure
I'm using a Free Air (IB) subwoofer, it's more like a home audio driver
 It would not do well ported I believe, most IB subs dont.
I prefer sealed over ported For my listening and music preferences
I'm trying to make the best with the equipment I have
Guess I'll just build a 4 cube sealed per sub box then play with a 5lb bag of polyfil if I'm not happy.
Thanks
Oh I missed that part. You do realize that IB is utilized by your trunk as an enclosure. And everything inside must be sealed up to sound good?
Indeed I do. But Infinite baffle is just a large sealed enclosure basically, right?
Manufacturer specs are 5.5 cubes each for sealed enclosure on these
I have 8-9 cubes max for space. I don't have a trunk, and im doing a very low budget setup.
2 18" is a lot of cone area (and I paid $99 for both)
It should have decent enough output for me.
 I'm just trying to understand more about how the drivers are going to behave in my alignment before hand
Capiche? Thanks
Manufacturer specs out 5.5 cubes in a sealed enclosure on drivers I have.
It should have decent enough output for me, I'm just trying to understand more about how the drivers are going to behave in my alignment before hand
Good point since I've never messed around with IB subs before and they weren't around long, not to mention that very little people used them. Wonder if @THATpurpleKUSH could help ya on your quest. Or @shredder2 for a design.
Poly fill does nothing but slightly absorb or rather diffuse the rear wave of the sub. This results in a cleaner sound which in return sounds similar to a larger box.
A better product that works much better is fiberglass insulation.
Different subs would be the solution or just try the subs you got worst case they sound bad and you can change them later
I read and searched for quite a while, I finally found the Info I was after and educated myself more on the subject.
Post can be disregarded now, thanks guys
For the record, the frequency response will more model like a larger box for you but you will not gain efficiency you would if you actually had that airspace.   Bear in mind your cabin gain may give you enough low extension where you don't need the curve you think you need to sound "good" and sealed boxes are quite forgiving anyway.   A 30% change in volume doesn't really even change the response graph much.
Easiest check is model the sub in WinISD to compare what you could even expect, or just buy 10$ worth of batting and test for yourself.
10-4.
Thanks
Poly fill traps the rear wave of the speaker keeping it from reflecting back and hitting the cone. This reduces 2nd order and 3rd order distortion...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
190
855
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
ThatChevyGuy
    Apr 26, 2024
    Apr 26, 2024
