Kenwood dmx905s won't control Spotify through Bluetooth
  • 2
yes it works when on android auto through usb. It has a spotify app you open when not on android auto but it says  disconnected even though the bluetooth is hooked up
go into your phone settings and forget the deck in your known connected bluetooth devices, repair and see if that helps. ive found that some things dont work the same over BT as it does over USB on my pioneer deck too. Seems like a limitation based on the model. I found out that many higher end decks will do virtually everything over BT that my deck is limited to doing over USB such as nav mapping and so forth
155
So I checked the ground wire. And god*am*tt, the frekin ground wire had wiggled out of the connector. Put a new connector on and everything works...
19
475
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
513
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Ppreedom
Ppreedom
youdoofus
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
