Kenwood dmx905s won't control Spotify through Bluetooth
  • 2
yes it works when on android auto through usb. It has a spotify app you open when not on android auto but it says  disconnected even though the bluetooth is hooked up
go into your phone settings and forget the deck in your known connected bluetooth devices, repair and see if that helps. ive found that some things dont work the same over BT as it does over USB on my pioneer deck too. Seems like a limitation based on the model. I found out that many higher end decks will do virtually everything over BT that my deck is limited to doing over USB such as nav mapping and so forth
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
195
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
568
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
537
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Ppreedom
Ppreedom
youdoofus
    Apr 28, 2024
    Apr 28, 2024
