M7 set screw
  • 4
Fastenal.
they dont have em either 😕
You have an odd ball. Try mutual screw or harbor freight after that idk.
yeah, its an Xtant A series. All its missing is the set screw for + or - the screw i have is in the - but theyre obviously the same. I took it to ace and they had a screw sizing thing on the wall that you put your screws in to see what size they are, and its an M7 narrow thread. Didnt think it would be this much of a PITA to get a replacement 😕
You maybe screwed. Doubt harbor freight has any. Mutual screw maybe. Mutual screw sounds like a nickname we had for a girl in high school.
I figured if anyone would have it it would be fastenal. They're my go to if I can't get it at the hardware store
Try McMaster-Carr
Edit: they have m7 coarse thread, however there is an m8 fine thread. Maybe re tap the threads for the m8 fine?
might have to do that. i drilled the M7 out anyways, but i know an M7 still fits because i took the other M7 out and it threads in just fine. Nice and tight. Id hate to retap it if i dont have to, ya feel me mayne?
It ***** doesn't it OP?
just finding a set screw is a real chore.
Try finding a service manual or schematic. Even voltage check points or talk to a tech about something
Not gonna happen..
No wonder this industry is dead.
The only place is....wait for it: China!
Made in the USA!!
YA sure it is uh huh. wheres those parts then?
These companies dont even answer phones or emails.
https://www.google.ca/search?q=gold+set+screw+grub+aliexpress&hl=en&prmd=ivns&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiLzL2G5ObfAhWO11QKHWzkAoEQ_AUIBQ
Not gonna happen..
Made in the USA!!
yeah... i called a local fastenal earlier today and the guy damn near laughed at me when i asked for an M7 set screw. He referred to it as illusive and wished me good luck. I asked about any ideas he might have and he suggested dying the hole to fit an M8
what I found is "M" is the diameter or width.
M7 is 7mm wide thread M7 10mm is 10mm long.
This is new to me.
https://www.aliexpress.com/item/200pcs-Stainless-Steel-Allen-Head-Socket-Hex-Grub-Screw-Multi-size-Socket-Head-Set-M1-M2/32919637970.html
that kit has 7mm but only 4mm long
https://www.aliexpress.com/item/240pcs-Black-Allen-Head-Socket-Hex-Grub-Screw-Set-Assortment-Kit-M1-2-3-4-5/32919629999.html
that 1 has 7mm but the  x 6 x 3mm I have no clue what that means.
I'm trying to find the same thing but for the speaker wires. I think they are 4mm
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
506
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
625
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
878
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
youdoofus
Skibidi
youdoofus
planet earth
youdoofus
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
