Buying new sub
What enclosure do you currently have the Kicker in? Measurements such as LxWxH,and is it sealed or ported.. if ported what is the enclosure tuned to?
you have to match the impedance, 4 ohm sub to 4 ohm amp, 2 ohm sub to 2 ohm amp.  most amps put out more power the lower the impedance, so you can usually get more power for your buck with a lower the impedance
Well just don't bring up funky pups again wouldn't want to run anyone off lol... some people have 0 since of humor apparently
oh man, the pups would wreak too much havoc for any one person to handle. I even feel like the CIA would be all over this IP address if i was to even mention their full name. the only safe way to mantion their name is with dashes between the letters.  f-u-n-k-y p-u-p-s
It's a good thing the op is going from kickers to jl and not kickers to funky pups. They'd be a lot more to worry about then just ohm load.
If your not dead set on the JL, there are more brands out there to choose from. JL is overpriced imo, and for the money can more than likely get you something better, cheaper.
The CIA estimates that 20% of all unsolved fatalities were noobs trying to install the pups.
its a damn good thing i wasnt drinking anything when i read that or i would have spat it out all over my monitors here at work!!
I agree. And if the OP is still around after the adhd derailment that was entirely my fault, id like to apologize to him/her
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
490
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
4
346
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
490
Poundsound
CarAudio.com Newbie
Poundsound
youdoofus
Doxquzme
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
