2017 Nissan versa s charging system upgrade
  • 2
Gingerbread man
Can you install a bigger alternator battery bank and do the big 3 on a 2017 Nissan versa s my factory positive cable has several solder fuses plus a wiring harness plug attched to it
When wanting a high output setup you can just re-feed the stock and then any audio wiring would be independent.  So just re-land the stock alternator cable on the HO alt then you run separate alt wiring for the sound system to the extra batteries.
You could also disassemble the stock terminal, add a new terminal on the larger battery, then run a wire jumper from the stock feed to the new battery terminal.  This assumes the new battery terminal has multiple outputs.
Note that you should have fusing on any wiring added to the batteries or alt.
You can buy some replacement OEM wiring harnesses aftermarket from a few places, ebay, amazon, sometimes metra has the part numbers on their...
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Ya man.. No telling how long that will last. you do one are and the weakest point begins to fail sooner or later. Looking at CDT speakers,. They...
I replied to your other thread. Id look at Infinity Kappas for the money on 6x9 components and an amp. But I would have chosen the kenwood over...
To find out what fits, head over to Crutchfield.com. For actual purchase you may want to try CDT.com. They seem to have an everlasting sale. Good...
Gingerbread man
Gingerbread man
keep_hope_alive
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
