Tuning w/ multimeter
  • 4
mousepwr
CarAudio.com Newbie
6
Hey everyone.
     I was trying to tune my JBL GTX500 using the multi-meter method. I multiplied the rms 350 x the ohms 4 and 1400, the square root of that is 37.41. I was only able to adjust the voltage to about 32v. does this mean the amp is bad? I just got it from Crutchfield.
  thanks
That amp surely does rated, and your math appears correct. Not sure what to say? possibly bad amp, idk. Try a different meter, or try your current meter on someone elses amp to rule the meter accuracy out.
I dont care for the new site.. And wtf is the top 15?
THATpurpleKUSH - "Weak voltage from the input source."
right on lol. i had assumed  OP had HU voltage set to 3/4 volume, and playing a sine wave.. What DB sine wave is the question?? Also,what do the rca volts read? Should be between 2-6 V AC
Must be an Alpine deck! I have that amplifiers and it’s awesome.
Also I hate the new site too and is why I stopped posting here much. I liked the old layout much better.
The head unit is a Pioneere mvh 200ex. Basically then I should keep the subwoofer level all the way up all the time, or just to tune it?
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
5
mousepwr
CarAudio.com Newbie
mousepwr
mousepwr
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
