JVC Arsenal KD-AR959BS
  • 2
LM3
Does anyone know how to get my iPhone 5S applications (Waze, Maps) to override the radio and speak directions? Does not work with my iPhone 6 either.
I believe it used to work but has stopped. The phones do work through the head unit.
the solution to any iphone issue is to get an android and be done with it ? totally kidding, but im a devout android user, so i dont know how to get that working for you. android auto on my nex unit is pretty fly
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on...
955
LM3
LM3
Baltimore, Md
youdoofus
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
