LOC Use
  • 2
bherron1985
CarAudio.com Newbie
I have a DS18 Candy Mirco4 that I’ll be using to power two speakers. I would like to add an amplifier to power a sub, which will allow me to install a volume control knob for the sub only, and the Bluetooth receiver I’m using only has one amp output. Can I use a LOC from the two unused channels from amp 1, and connect RCA cables from the LOC to the second amp? Any other suggestions are welcome!
You can also install an RCA splitter to divide the signal after the BT receiver.   Usually, a male to dual female RCA splitter is what you need for both left and right.
You can also split 3.5mm stereo in the same way - one male to two female then adapt 3.5mm to RCA stereo if need be.
Your idea will work but is difficult for level setting.
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
794
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
632
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
unfortunately no empties but a couple promising choices, out of town right now have to this weekend 1) Car Radio Switch, Climate Control System...
5
bherron1985
CarAudio.com Newbie
bherron1985
keep_hope_alive
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
