Buck builds a single 15 box
Buck
little alien on campus
I cut these pieces with a circular saw on some dude's back porch and assembled it with very limited tools. Turned out well. Box is for a DC level 3 15. It's @ 33 hz.
Paint on the box is still being decided on, waiting for the sub to get here. Amp is a cheaper 2 channel for now, will upgrade to a monoblock in the future. This isn't my box, a friend's box, it is.
I did it free hand with a circular saw lol. I don't personally have a lot of tools but I at least got a couple of clamps to use from dude so that's one of the most important things.
This little thing should rock.
Not bad. About to build a sealed box for a IDQ12 using my 4 speed jigsaw freehand. Cuts pretty quick and straight enough.
Are you adding 45's in the corners?
I cut all my holes with a jig saw. Nuttin to it.
All you need is a paint paddle and 2 drywall screws. Measure the radius you need then use 1 screw as the centerpoint to hold down the paddle and the other screw where you want the line with the tip poking out about 1/8 inch from the bottom of the paint paddle.
Easy circle scribe that even fits in Gramps's budget.
Pretty interesting interview/debate
550
https://www.amazon.com/gp/product/B0016G4EXQ/?tag=caraudiocom-20 https://www.amazon.com/gp/product/B07BMT699G/?tag=caraudiocom-20 Im not a fan of...
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
Right now I have D2 and D1 options. In about month and a half I have a sh*t ton of parts that should be here. 4" coils should be in that bunch. I...
39
4K
Buck
Buck
Inside of a pyramid
THATpurpleKUSH
Brendon Jenness
    May 8, 2024
    May 8, 2024
