I think i made a mistake....
  • 3
I paid a guy to make me a box. He did a great job but he ended up putting the subwoofer mounting hole on the wrong side, so the problem I was running into is my subwoofer wood hit the port wall before it's all the way in. So I made a hole in the port wall to fix the issue, and the subwoofer fits perfectly, but now I'm wondering is this hole going to make the box sound horrible...Does anyone know if I need to be concerned about this????
Pictures Below...
Yea you prolly destroyed your box. You should've had him replace the board with the mounting hole instead of cutting a hole in the port wall.
You really just screwed the port tuning
Your sub is firing right into the middle of your port. I would cover your hole and maybe invert the sub until you can get a new box.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
527
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
5
553
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
735
I feel the same way. I do wonder if the build of the stealth can handle the additional 200 w rms of power of the w6v3 since it will apply more...
4
887
BigSteve757
BigSteve757
Virginia Beach, VA
BigSteve757
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
