Door glass vibration
  • 2
psylo535
tampa,fl.
I'm getting a terrible vibration that is definitely coming from the glass when I play at loud volume. Got 6.5 hertz in the doors with a bridged soundsteam TN4.900D. I've tried everything I could think of but it is still there and very annoying. Anyone else have this problem, and a solution ?
only thing i could think of is mount mdf to door on top of mat, then mat the mdf and screw speaker to that but u may not have enough space
I already have a ton of sound dampener. It's not the door or panel it's the glass that's vibrating and only the drivers side for some reason
man you'd have to take door apart and tighten something up on window.. without that shove something in track beside window see if that helps, start with paper or thin card board, lol matchbook my generation used those for everything..
Yeah,had the door apart recently to change the window regulator and everything looked fine. It never did this till I put more
Power to the mids. Can’t really put anything in the track or it will just fall out when I put the window down. Guess I’ll just live with it
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
227
Tons of options in that budget, including the cost of installation,
10
606
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
378
psylo535
psylo535
tampa,fl.
psylo535
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
