My First Build. Chrysler 300
znewberry
Illinois
Hey guys,
This is my first system I have ever messed with, installed or ever owned. Any knowledge I have is strictly from internet research so feel free to chime in at anytime during the build.
[Alternator]
a) Stock Denso 180-amp OEM#421000-7041
[battery]
a) Duracell Platinum AGM Battery CCA=850 CA=1000
[big 3 Upgrade]
a) 1/0 grounds.
[Head Unit]
a) Stock Head Unit
c) LC8i
[subwoofers]
a) Untouchable Sounds King Series 12” 2000w RMS
b) Untouchable Sounds King Series 12” 2000w RMS
c) Enclosure tuned to 35hz. Trunk Sealed. Ported and Firing to cab.
[Amplifiers]
a) Soundstream Picasso 3500d Mono ** UPGRADE SOON! **
[Mids and Highs]
a) All stock ** UPGRADE SOON! **
[Misc. Equipment]
a) Stinger SVMB Voltmeter
1/12/2018
FIRST DRY FIT WITH BOX Plenty of room on left and right corner for batterys and a nice amp rack on the long wall.
https://ibb.co/dNySCR
https://ibb.co/g9dSCR
**UPDATE**
I threw everything together to hear the new box from stock deck / same soundstream amp. I cant wait to upgrade the mono and start mids/highs! LC8i will be in it this Saturday.
Video ----->
**UPDATE**I threw everything together to hear the new box from stock deck / same soundstream amp. I cant wait to upgrade the mono and start mids/highs! LC8i will be in it this Saturday.
Video ----->
wow mms on those subs is very low should be easy to move but fs is only 50hz
Yah I saw the FS after I purchased. I picked them up from the actual creator at his shop about 45min from here. Nice to rock local gear, i wish that fs was like 32 tho
How did the loc / Lc8i work out? I hate using locs but im in same boat with a newer car that has everything integrated with the stock head unit and hvac stuff.
The LC8i will be installed this saterday. I have looked into several options Fix 86 , SC4.1 , LC8i .. ultimatley i decided on the lc8i. Ill post a sound check after some tweeks this weekend.
znewberry how did the lc8i work out?
I sorta felt like I was "settling" with the lc8i or fix86 or w/e similar units...After having the LC8i in hand and almost installing it I at the last minute decided to do something better. Which I was going to avoid but I said f*** it go "bigger"
No more lc8i I sent it back.. I am waiting for my new parts to get here wednesday. I will be adding a dash kit with a 7" in dash double din deck that sits right below my 8.4" screen. I will link parts below.
Pioneer AVH-2330NEX https://www.crutchfield.com/p_1302330NEX/Pioneer-AVH-2330NEX.html?tp=20217&omnews=14251039
Axxess ASWC-1 Steering Wheel Control Adapter https://www.crutchfield.com/p_120ASWC1/Axxess-ASWC-1-Steering-Wheel-Control-Adapter.html?tp=3405&omnews=14251039
Metra 40-EU10 Antenna Adapter https://www.crutchfield.com/p_12040EU10/Metra-40-EU10-Antenna-Adapter.html?tp=2569&omnews=14251039
Metra AX-USB-MINIB USB Port Cable https://www.crutchfield.com/p_120AXMINIB/Metra-AX-USB-MINIB-USB-Port-Cable.html?tp=3486&omnews=14251039
Posi-Products Car Stereo Wiring Harness Connectors https://www.crutchfield.com/p_669PP500/Posi-Products-Car-Stereo-Wiring-Harness-Connectors.html?tp=61469&omnews=14251039
Metra 99-6525B https://www.sonicelectronix.com/item_105679_Metra-99-6525B.html
Here is a manufacture video of my exact make/model car with the kit.
^that's probably the best choice just to get a new head unit. I am in same situation in my G8 GT, everything is tied to the stock head unit and also the hvac is tied in. Just the kit alone is $800ish and comes with an lcd screen to control the hvac air / heat and the wiring with a facia kit (no head unit including) so that's another $300-$400+.
From my research a good head unit is best. however the FiX 86 does still give a ****** EQ with ur laptop usb hooked up. ultimatley i got everything for $742... the lc8i was almost 300. thats a difference of $442 its pretty big but well worth it.
I also plan on adding Lockpick c8 so I can unlock nav/video on factory screen also while in motion.
What year is ur car I can try to find a kit cheaper. Also another idea is buy a nice singe dinn deck and put that ***** in the glove box or under a seat or wherever and hardwire a remote / usb
Took me $762 and 7 hours but here is the new dash kit and double dinn //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
your g8 replaced my grand prix always liked those.. u know they still make them in Australia right? guy told me yr before they came out u know they making a 4 door gto i was like nah and sayw they had them over there already.. just like they made the g8 pickup over there (like a small el camino) were gonna make it here in 2010 but pontiac went away..
Yep, the g8 GT is basically a Holden Australian car. They are really nice cars. I have seen the g8 with a bed, it's called a Ute, short for utility. They also have a g8 wagon in Australia. I've always been a gm guy. I always wanted a g8 GT since when they first came out. I was lucky enough to get a pretty low mileage one 4 months ago that was very well taken care of. I do like the Pontiac Grand Prix as well.
yeah they also still have the ford falcon been making it there like 50 years lol..
16
660
852
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
733
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
804
znewberry
znewberry
Illinois
BOOMINGRANDPA
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
