FS: Morel Elate 6 2-Way
6" Elate SW 2 Way Component System
Nominal Impedance: 4 Ohm
Power Handling: 200W
Max. Transient Power Handling: 1000W
Sensitivity (2.83V/1M): 89dB
Frequency Response: 25-25000Hz
Crossover Point: 1800Hz
Voice Coil Diameter
Woofer: 75mm (3")
Tweeter: 28mm (1 1/8")
Voice Coil Wire
Woofer: Hexatech Aluminum
Tweeter: Hexatech Aluminum
Magnet System
Woofer: Hybrid rear vented
Tweeter: Double Neodymium magnet
Mounting Depth
Woofer: 61mm (2.44")
Tweeter: 20mm (0.8")
Have been installed since 2011. No unusual wear or damage. Ran them active so I never used the crossovers. Includes 4 Tweeters total, one is damaged and can be used for parts. 3 Total working tweeters and multiple mounts. Do not have the original box. Will ship well packaged.
$600 shipped to the lower 48 and to include tracking upon payment.
Thanks,
Kevin
https://photos.app.goo.gl/3F3nQe7jiwa3NCsb2
https://photos.app.goo.gl/c0H6T7jZhJDs4B343
https://photos.app.goo.gl/1SiAACVamKkzmGkj1
https://photos.app.goo.gl/VGEs4WJJrNsygzV63
Op you should probably mention that those are the Morel Elate 3 way crossovers you have there, the crossover points are different from the 2 way crossovers that came with the 2 way elates.
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
Nice thing about the Morels is they don't require a lot EQ. Since the midbass will likely be far from the mid & tweeter, you could benefit from...
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
kpctoy
kpctoy
Upstate South Carolina
sensarmy
Brendon Jenness
    May 8, 2024
    May 8, 2024
