mr b 10+ year member
$160 O.B.O. Incriminator Audio IA 10.1 Tested by world famous Audio Engineer Bernie Boland from Boland Audio!
Pretty **** good! Normal scratches associated with installation. See pictures below to see condition. It is not brand new so not perfect but looks good. Bass knob and cable not included but are cheap enough from Incriminator Audio.
This was running 2 12" subs at 2 ohms for 19 months. Never put into protection mode.
Features:
Digital Class-D Linkable Mono Block Amplifier
Dual MOS-FET Pulse Width Modulation Power Supply
1 Ohm Stable Topology / 16 Volt Stable
Heavy Duty 3 Oz Copper Layer Double Sided Epoxy PCB
Extremely High Tolerance Electrical Components For Reliability
Proprietary Custom Tooled Heatsink with Onboard PCB Support For Vibration Resistance
High End Silver Tiffany RCA Inputs with Metal Potentiometers
Black Molded Oversized 4 AWG Power and Ground Inputs
Advanced Strapping with Mirror Technology
Multi-Layer Built Proof Protection Circuit
Remote Bass/Gain with Clipping Indicator
1 Year Limited Warranty
Specifications:
Rated Power ( 14.4V at 1% THD )
RMS Power - 2 Ohm Linked : 2400
RMS Power - 1 Ohm Mono : 1200
RMS Power - 2 Ohm Mono : 800
RMS Power - 4 Ohm Mono : 400
Low Pass Filter ( 24dB/Oct. ) : 35Hz - 250Hz
Subsonic Filter ( 24dB/Oct. ) : 10Hz - 50Hz
Frequency Response ( +/- 1dB ) : 15Hz - 270Hz
Bass Boost ( 45Hz ) : 0 - 9dB
Input Sensitivity ( Volt +/- 5% ) : 6.0V - 0.2V
Signal / Noise Ratio : 95dB
Dampening Factor ( 1 Ohm ) : 350+
Operation Mode : Master/Slave/Mirror
Power Efficiency ( 4 Ohm ) : 85%
Fuse Rating ( 14.4V ) : 125A
Fuse Rating ( 14.4V Linked ) : 250A
Power Input Connection : 4 Gauge
Operation Voltage : 8.5V - 16.0V
Speaker Output Connection : 8 Gauge
Dimensions ( Inches ) : 7.48 W x 2.24 H x 12.60 L
Dimensions ( Millimeters ) : 190 W x 57 H x 320 L
Manual http://www.incriminatoraudio.com/download/IASeriesManual.pdf
$160 OBO
$13.50 West Coast - 16.50 Mid-West - 18.50East Coast Actual shipping costs will be charged.
Features:
Specifications:
$160 OBO
