Made to order grills, rings, Equipment for mounting speakers
I made for you. Supporting rings, holding the safety net, body parts, the volume for speakers.Equipment for mounting speakers. aluminum only. Steel Grid (Grid choice for photo or describe the specification). Dimensions can be any on the design or brand din and wishes in the form of external processing of the front surface - Decorative risk, polishing, Can painting. It's simple. Price by agreement.
Several options for photo:
"][/url]
"][/url]
"]http://[/url]
"][/url]
[/url]
More photos of my work here:https://yadi.sk/d/AMNurCZOqpaY8
You do very nice work.
You might want to give a price on some specific versions and sizes in order to comply with the posting rules for sale ads.
As hard as it is to find grills for subs, you might so some good business here.
Oh sure. An example of the work - mid ring, as in the photo: "]
[/url]"][/url]. The outer diameter of up to 200mm
US $ 60-70 (2 pieces)+ EMS delivery.
The outer diameter of 200mm-250mm (2 pieces) - US $ 80-100
The outer diameter of 250mm-300m (1 piece, subwoofer) - 65-100 USD
more than 300 mm - from $ 80 and up
Protective grid included. The cost depends on the thickness and outer diameter of the ring, the outer finishing.
Support rings - the price is less. These are the (support and mounting): "]http://uploads.ru/04XYN.jpg
[/url]"]http://[/url]"][/url]
If someone buys from him and has a good transaction put some feedback up please //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif Beautiful work for sure.
I just ordered two pair for my anarchy door build out. I will let you know how it goes good or bad. So far guy seems cool.
If this is the same guy I am thinking of...there are some over at DIYMA that have done business with him and were very happy with the transaction.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
601
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
615
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
821
I feel the same way. I do wonder if the build of the stealth can handle the additional 200 w rms of power of the w6v3 since it will apply more...
896
Alexander612
Russia, Rostov region
SilverSquared
Brendon Jenness
    May 8, 2024
    May 8, 2024
