MTX TA7801 intercooler fan problem (Help)
  • 2
haynaudio808
Aloha new to this forum,
I recently got a ta7801 from a friend and it performs great but only problem is the internal fan doesn't shut off completely even after i turn off my amp. Tried it with the HU remote wire and with a inline switch same result fan doesn't shut off. Anyone with any insight on this?
Thanks.
Aloha new to this forum,I recently got a ta7801 from a friend and it performs great but only problem is the internal fan doesn't shut off completely even after i turn off my amp. Tried it with the HU remote wire and with a inline switch same result fan doesn't shut off. Anyone with any insight on this?
Thanks.
So it stays on indefinitely if the amp is hooked up?
hmm i was thinking maybe it was meant to stay on for a little while after the amp shut off or it was just using up some left over power in capacitors but i guess none of that makes sense. its getting power from the constant input somehow, i would probably rewire it a switched source like the remote turn on, but sorry, I have no input as to why its doing that. have you opened the amp case to look inside by chance?
Yeah thats what I thought at first but I checked on it an hour later and it was still on so I'm stumped. But no I haven't yet, ill have a look tomorrow. Oh and also i had it wired to a switch and it still would stay on.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
708
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
haynaudio808
haynaudio808
Honokaa, HI
haynaudio808
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
